Issue with Brave Sync chain: sync words showing as expired
Hello Brave Support Team,
A few months ago, I transferred all my Brave Sync data to my new computer. At that time, I carefully saved the sync words for my Sync chain, since they were the only credentials I had to recover my synced data.
Recently, I had to restore my computer. When I tried to set up Brave Sync again using those same sync words, Brave showed a message saying that they had expired. I am sure these are the correct words because I had already used them before to set up Sync on this same computer. I also saved these sync words only about two months ago, so I do not understand why they would already be expired.
Could you please explain why the sync words are showing as expired if they are supposed to belong to an existing Sync chain that I had already used before?
I would also like to know what options I have to recover or regain access to my synced data, since these are the only sync words I have saved.
Is there any way to reactivate the Sync chain, recover access, or verify whether the Sync chain associated with those words still exists?
Thank you.
I found this solution in some old posts in the Related section at the bottom of this page:
Thankssssss youuuu!!! It works perfectly.:handshake:
