Upon using the fullscreen button for the browser, it blocks out all the tabs from being viewed as compared to my MacBook pro which doesn’t replicate the issue. Not sure if it is only for iMac’s
Fullscreen issue with iMac 27in 5k 2017
- The issue can just be reproduced just from full screening the brave browser, all the tabs and web address bar aren’t visible unless you go to the tab option at the top of the screen.
1.7.98
This same issue doesn’t happen on my 2018 Macbook pro as stated before. Only on my iMac
