Issue connecting Brave Wallet to Brave Rewards after PC reinstallation
Briefly describe your issue: I am unable to reconnect my Brave Rewards to my custodian account. Everything was working perfectly before, but I recently had to reinstall my PC (operating system). Since the reinstall, I cannot link my account back. I have attached a screenshot of the error message I receive during the connection process.
What Operating System and Brave version are you using? Windows 10/11 (64-bit) Brave Version: 1.85.118 (Official Build) Chromium: 143.0.7499.169
Are you attempting to connect via Solana? If you have previously connected 4 devices or profiles to this address, you must use a different Solana address.
Just want to add to this since it may get brought up: Reinstalling a PC usually shows up as “a different device” to most services. So if you indeed had 4 devices prior to the reinstall, would make the reinstalled PC appear as a “fifth” device.
Just in case there was any confusion there.
I am also facing this same issue, I also reinstalled windows and now I also getting this message, I had total three android devices and one windows pc connected to same wallet but after reintalling windows on my pc it’s showing this error, is there any way to solve this issue, please do reply
