Who is your verified custodian? (Uphold/Gemini/bitFlyer) Binance?
Are you in a supported region? (see here for list of supported regions) Yes
Im trying to connect Brave Rewards with my Binance wallet (add-on), but in the end its fails with Something went wrong message. I had before connection and got my rewards lately. But after re-format PC and installing Brave I cannot connect anymore.
Yeah . . . maybe, after the “re-format PC and installing Brave, I cannot connect anymore” . . . consider the info at the Brave Rewards links, listed at:
-Daily Brave Ads appearances - #2 by 289wk
You might gain a different perspective / opportunity, and proceed on a different course?
While you wait for help ← if you choose to stick with the Binance wallet.
