Is the right place to flag sites that have recently started with pop ups?
Hi All,
Fairly new to this, so please excuse an dumb questions as a result of my ignorance.
Is it possible to report here sites that up until recently have been sorted by shield but are now having multiple pop ups appear whenever you click on anything on page?
Yes, this is the right place for that. When you opened this thread there were some questions in the editor that will help us root out the issue, can you please answer them?
Does the ad appear when using a Private window as well? (yes/no)
What OS are you using when you see the ad?
Description of the issue: when clicking on just about anything a new opens with ad
Exact URL of the website in question: https://mangareader.to/
Did the issue present with default Shields settings? (yes/no) yes
Does the site function as expected when Shields are turned off? no
Does the ad appear when using a Private window as well? (yes/no) yess
What OS are you using when you see te ad? MacOS
Version 1.77.95 Chromium: 135.0.7049.52 (Official Build) (arm64)
[/quote]
sorry for the late reply
Yeah I’m seeing the redirects as well – certainly super annoying. Will have someone take a look at this.
Should be fixed when we landed this earlier today; https://github.com/brave/adblock-resources/pull/245
@fanboynz thanks for the update. Just tested on my end and still getting the popup :frowning:
All, did was refresh the page. should I have taken more steps?
Thanks again for all the quick returns!
Special mention to @Mattches
@spinkspete,
Can you confirm that you’re using the latest version of the Brave Ad Block Updater? You’ll find this by opening Brave and going to brave://components and ensuring that the Brave Ad Block Updater component is fully up to date.
