Pop up ad on click
Description of the issue: pop up on click
**Exact URL of the website in question: https://www.mgeko.cc/reader/en/reincarnation-of-the-swordmaster-chapter-6-eng-li/
Did the issue present with default Shields settings? (yes)
Does the site function as expected when Shields are turned off? Yes
Does the ad appear when using a Private window as well? (yes)
What OS are you using when you see the ad?MIUI Global 14.0.6 (android 13)
**Brave version (check About Brave): Brave 1.66.118 **
Fix incoming, give it a few hours to roll out.
