Ads, pop ups are showing
**Exact URL of the website in question: manga-raw.club **
**Screenshot of the ad as it appears in Brave
Did the issue present with default Shields settings? (yes/)
Does the site function as expected when Shields are turned off? Yes with ads
Is there a specific Shields configuration that causes the site to break? If so, tell us that configuration. (yes): block scripts
Does the site work as expected when using Chrome?yes, with ads
**Brave version (check About Brave):
