Fullscreen Mode Issues on MacOS
The current behavior of MacBook Pro M2 and M3 series in MacOS fullscreen mode can be quite frustrating. The window control buttons are hidden by default, requiring you to move the cursor to the top of the screen to reveal them. This action hides the tabs as the buttons appear below the menu bar. Additionally, this can be annoying when you accidentally open the menu while switching tabs using the trackpad or mouse.
Brave’s Current Behavior:
CleanShot 2024-05-21 at 16.38.48
Safari’s Implementation:
Safari handles this more elegantly by integrating the buttons into the UI, completely hiding the secondary bar:
CleanShot 2024-05-21 at 16.32.24
Opera’s Solution:
Opera also offers a seamless solution. Although Opera is slower than Vivaldi, I might switch to it because this fullscreen feature is crucial for me as I always use my browser in fullscreen mode:
CleanShot 2024-05-21 at 16.34.58
Google Chrome’s Behavior:
Google Chrome also shares the same behavior as Brave, with the window control buttons being hidden by default and requiring the cursor to be moved to the top to reveal them, causing the tabs to be hidden:
CleanShot 2024-05-21 at 16.39.35
Vivaldi’s Behavior:
Vivaldi exhibits the same behavior as Brave, where the window control buttons are hidden by default, requiring the cursor to be moved to the top to reveal them, which in turn hides the tabs. I couldn’t add more than 4 gifs due to new account limitations.
Anyways, I hope this gets added to Brave soon.
Wow brother thank you so so much, Immersive Fullscreen Toolbar flags actually worked for me. It didn’t work on Vivaldi, only worked on Brave. So now brave will be my first choice. Its a little bit buggy, sometimes those buttons don’t go away when mouse is not hovering, but thats even better. :star_struck:
I think Brave should enable this by default on MacOS, as its a deal breaker for many people. Most people aren’t able to search and set flags.
Even for me it took 4 months to post this here.
CleanShot 2024-05-22 at 07.54.18
#enable-immersive-fullscreen-toolbar is removed in new update. We are back to square one.
yes , is there any other solution for this ?
This is very annoying. Since there seem to be no ways to fix this, are there any workarounds?
Super annoying behavior, and seems to affect a lot of Mac apps. So far the only workaround I found was to switch to Windows or Linux.
Frankly, if a bug is in one app, it’s a problem with the app. If the bug is in 50% of apps, it’s a problem with the OS.
I’m still having this issue as well. Is there any work around yet? It’s driving me nuts.
Meanwhile, in Chrome everything works perfectly in full-screen mode. Why is it so difficult to implement it the same way as in Chrome?
