I want to remove the minimize and close buttons on the top of my toolbar, but I also want to keep the toolbar at the top without disabling the “Always show toolbar in full screen” option, does anyone have a possible fix that could keep the toolbar at the top while also removing the minimize and close buttons at the top?
I don’t think Brave has a separate setting for that. On macOS those red/yellow/green window buttons are drawn by the window frame, so if the toolbar stays visible in full screen they normally stay there too. The only practical workaround I know is using the normal full-screen mode without always showing the toolbar, or hiding the whole toolbar with the existing option.
Alright then, thanks alot for the info, I thought there might have been a option to like disable it or something, but I think I’ll simply stick to keeping “Always show toolbar in full screen” off until they either have a option for it or maybe something else.
