[Feature Request] Remember YouTube playback speed and quality settings on iOS
Summary
I’d like Brave on iOS to remember and persist YouTube playback speed and video quality settings across videos and sessions.
Currently, every time I open a new YouTube video in Brave on iOS, the playback speed resets to 1× and the quality reverts to Auto. This means I have to manually re-select my preferred speed (e.g., 1.5× or 2×) and quality (e.g., 720p or 1080p) for every single video.
Requested behavior
Primary request — Playback speed persistence
  • When I set a playback speed (e.g., 1.5× or 2×), that setting should be remembered and applied to subsequent YouTube videos automatically.
    • The speed should not reset after pausing/resuming, navigating to a new video, or reopening the browser.
  • Secondary request — Video quality persistence
  • When I manually select a video quality (e.g., 720p, 1080p), that preference should be remembered for future videos.
    • Ideally, separate defaults could be set for Wi-Fi vs. mobile data (similar to YouTube app behavior).
  • Why this matters
  • Many users watch YouTube at increased speed (1.5×–2×) for educational content, podcasts, and long-form videos. Having to reset speed on every video is a major friction point.
    • On older devices or slower connections, Auto quality often selects a resolution that’s too high or too low. Being able to lock in a preferred quality saves time and battery.
  • Prior community discussion
    This has been requested multiple times over the years, indicating sustained user demand:
  • Playlist keeps resetting speed on play (2021) — speed resets to 1× on every video/pause
  • Device info
  • iPhone / iPad
    • iOS / iPadOS (latest)
      • Brave iOS (latest stable)
Note on existing “Highest Quality Playback” setting
Brave iOS already has a “Highest Quality Playback” option (On / Allow over Wi-Fi / Off) in Settings → Media. However, this setting is insufficient for the needs described above:
  1. It has no effect on playback speed — it only controls quality, not speed persistence.
    1. It’s too coarse for quality control — it only toggles between “highest available” or not. It does not allow setting a specific quality cap (e.g., 720p or 1080p). Even on Wi-Fi, if the connection is slow, Auto may select a resolution too high for smooth playback, causing buffering and stalling.
      1. It doesn’t always work — past reports indicate that even with this setting turned Off, Brave still selects the highest available quality (see prior discussion #582981 above).
    2. What’s needed is a more granular control: the ability to set a maximum quality limit (not just “highest or not”), ideally with separate limits for Wi-Fi and mobile data, regardless of actual connection speed.
