Youtube not displaying all the quality options for videos. eg: max quality 360p or 720p, but when using Safari on the same video it displays every quality option, even 4k 60fps.
However, the video will play at its max quality option if set to Auto Quality, even if it displays no higher option than 360p.
- Go to youtube
- search for any video, but if you search for 4k you know the quality settings go that high
- open the quality setting on youtube by tapping the cog icon.
4 observe the options given. there will be fewer than in safari or other browsers
all quality options given. seems to have been introduced w ith the latest brave update
1.4.8.1
Mobile Device details
ipad pro 12.9 inch 2022
seems to work fine sometimes, but not others, especially when using airplay
