Facebook logout/login problems - Latest Brave for mobile
Login to m.facebook.com suddenly possible only once after cleaning browser data. After coming back again => auto-logout and no further login possible (loads forever - see screenshot) fb-forever-load7 unless another browser data cleanup:
1.m.facebook.com
2.login only possible after cleanup browser data
3.cone back to tab
4. auto log out occurs => no login possible (loads forever - see shot)
5. cleanup browser data
6. login possible
7. see 3 (catch 22)
no auto logout and possible login
tons of times - happens always
Brave Version(about:brave):
1.0.71
Mobile Device details
Huawei Honor 9
Android/iOS Version
8.0
Iit always worked with former Brave versions.
I did not change settings or installed new plugins.
In mobile Chrome it works without a problem
Hi @paulaschaefer
Thanks for reporting :slightly_smiling_face:
Can you click Brave icon at top right and share your shields setting for Facebook?
Thanks
hi @eljuno, thx and sure, see shield settings attached. but even deactivating all shields followed by app restart with cache delete. same result.
great holidays! best, paula
and now a google search is not posdible anymore with the same shield options on mobile. it stays on a continuous loop in the captcha dialouge. lg, paula
Can we reinstall it?? Is it possible??
thanks
kissanime
no bookmark export, right? :slight_smile:
Apologies for late response @paulaschaefer,
I’m not able to reproduce the issue. Will cc @sriram @Mattches for additional test.
@paulaschaefer,
I’m unable to reproduce this on my end on my Android device. May be an issue with Huawei devices. Did this issue only just now start to present after the update or have you experienced this before?
@mattches, I just happened a few days ago - without any Huawei update.
This morning it suddenly works again without me doing a thing.
Maybe Facebook changed something and reversed it to the best…
