Summary
When using Proxy SwitchyOmega 3 (ZeroOmega) with a Switch Profile (proxy selection based on hostname), Brave leaks DNS requests to the system/ISP DNS.
The same extension and configuration works correctly in Google Chrome with no DNS leak.
Environment
Extension: * Proxy SwitchyOmega 3 (ZeroOmega)
- Users: 600,000+
Brave Version:
Brave 1.85.118 (Official Build) (arm64)
Chromium: 143.0.7499.169
Chrome Version: 143.0.7499.170 (Official Build) (arm64)
OS: macOs 15.7.3 m3
Steps to Reproduce
Install Proxy SwitchyOmega 3 (ZeroOmega) in Brave
Create a proxy profile (SOCKS5)
Create/Use the Auto Switch Profile that routes traffic based on hostname rules and make the proxy profile defualt.
Enable the Auto Switch Profile
Visit a DNS leak test site
Observe DNS resolving via system/ISP DNS
Repeat the same steps in Google Chrome
Observe DNS resolving through the proxy (no leak)
Expected Result
DNS requests should be routed through the proxy when a Switch Profile is active.
Actual Result
DNS requests bypass the proxy and leak to system/ISP DNS when using a Switch Profile in Brave.
