Description of the issue: In DevTools (F12), “Sources” tab, the text selection has very low contrast, making it difficult to distinguish.
- Open DevTools (e.g. by pressing shortcut key “F12”)
- Ensure it is shown in Dark Mode
- Navigate to any website
- In DevTools, go to “Sources” tab and select any javascript or css file
- Select any part of the source file text
- The contrast between the selection and the background is very low
When using Light Mode, the contrast is fairly good (but could be better).
Expected result: The contrast between the selection and the background should be clearly visible, either using Light Mode or Dark Mode
Brave Version( check About Brave): 1.21.77
