Click to download or upload not working
I AM UNABLE TO DOWNLOAD OR UPLOAD ANY FILES FROM Brave
I can recreate the issue.
-Open a web page and then try download it (via option on page) download never happens
-Tried to upload a copy of a receipt (jpg) , unable to upload (file select dialog opens) no file is uploaded
  1. Brave v1.74.48** (Jan 15, 2025)
  2. Ubuntu 24.04.1 LTS
Expected result: Download or upload of the file/jpg
I disabled Shield and tested , unsucessful
Please Download The Test File and report the success or failure.
A simple text (TXT) file. The contents are one word: ‘test’:
testFile.txt (4 Bytes)
Happening to me as well on Linux Mint 22.1 Just started with this update
HI
I click on the test.txt (link) file, it does not download.
@Jibril , @zac3 ,
Usually, in a Linux OS command line, you can start Brave Browser with one of the following commands:
brave -n --args --incognito --no-experiments --disable-extensions --disable-gpu
or
brave-browser -n --args --incognito --no-experiments --disable-extensions --disable-gpu
In order to determine which of those, to use, in a Brave Browser New Window, go to: “brave://version”
Scroll down to “Command line”
The beginnings of that command line character string, will indicate to you, which of those commands to use.
The switches are intended to:
  • Start up Brave Browser, showing a New Private Window
  • Disable all experiments at brave://flags
  • Disable extensions
  • Disable GPU ie disable Hardware Acceleration
Test your issue.
You might create an additional Brave Browser Profile, for testing.
The important BraveSoftware folder location, usually but not always:
/home/[username]/.config/BraveSoftware/
OR, in a Brave Browser New Window, go to:
brave://version
and scroll down to “Profile Path” - that path very likely ending with “Default” - and locate the “BraveSoftware” folder in that path.
That is a folder to be backed up routinely, IMHO.
Sometimes, after exiting / quitting Brave Browser, then moving that BraveSoftware folder to another location, and then exiting and quitting everything else . . . and a computer restart . . .
And then starting Brave Browser . . . a new BraveSofware folder will be created.
That, sometimes, fixes some problems.
Hi, started from the command line ,Tried to download the test.txt , unsuccessful.
I also tried to open the test.txt files as a new tab, a new tab flashes up but closes, any way to see a log for an error why the tab closes ? I will try the new profile later.
HI
I created a new profile , but the same result, no download pop up.
Try to download the test file by using another Internet browser?
If i need to download/upload a file I switch to Firefox :frowning: works there, but I would like to stay with Brave
Thanks: Downloading the test file by using Firefox.
https://ubuntuforums.org/showthread.php?t=2502202
https://stackoverflow.com/questions/73267662/ubuntu-22-04-unable-to-upload-files-using-chrome-or-firefox
download of test file in Firefox worked
I checked both links , issue still there
upgrade to 1.74.50 Chromium: 132.0.6834.111 (Official Build) (64-bit) , issue remains
@zac3
Looking for related, similar issues
https://github.com/brave/brave-browser/issues/42473
https://github.com/brave/brave-browser/issues/43082
@fmarier may be able to help you proceed.
Looking at some older issues:
Potential Security issue with Brave download file handlers
Downloaded files not going to correct folder
Also, the Internet Download Manager:
Internet Download Manager (IDM) Integration Module didn't work on Brave Browser? - #2 by 289wk
To move forward I have added a download manager extension, able to download the the test.txt file.
