I have my downloads set to Downloads folder in Internal Storage and most files download correctly to this folder
However, for some reason, when I download an .srt file they don’t go into my downloads folder but instead I find them in Movies folder. I’ve tried again and again with similar results.
Application version
Brave 1.38.119, Chromium 101.0.4951.67
Operating system
Android 11; Build/RP1A.200720.011
MIUI Global 12.5.7
MIUI version
Stable 12.5.7.0(RGGMIXM)
Android version
11 RP1A.200720.011
289wk
May 24, 2022, 9:38am
2
Ref.:
Possibly . . . look thru your Brave Browser > Settings, for something that looks like it would re-route or re-direct a media file.
Perhaps some auto-play feature requires a media file to download to a certain folder.
Or an Extension is involved.
Nothing I can find. On Mobile so have no extensions. It doesn’t send the .srt file to a program to open, it just downloads it into this folder
289wk
May 27, 2022, 2:37am
4
@spiracles
If you are feeling energetic, try to disable the influence of the website . . .
This section - because it allows Brave Browser to start up without a burden:
In a Brave Browser > New Window, go to: brave://settings/getStarted
Select: Open a specific page or set of pages
Select: Add a new page
Enter: about:blank (notice the colon)
This section - to clear away cache and cookies:
Go to: brave://settings/clearBrowserData
For tab Basic - set:
Time range:All time
Enable: Browsing history
Enable: Cookies and other site data (Signs you out of most sites)
Enable: Cached images and files
Click on the “Clear data” button.
(The “Clear data” button also saves the selections.)
This section - because Google things:
Go to: brave://settings/shields
Disable: Auto-redirect AMP pages
If you have an older version of Brave Browser, try:
Disable Enable De-AMP at brave://flags
This section in order to keep control in your court:
Go to: brave://settings/content
Scroll down to “Additional permissions” . . . and set:
Protocol handlers: Don't allow sites to handle protocols
File editing: Don't allow sites to edit files or folders on your device
Clipboard: Don't allow sites to see text or images on your clipboard
Window placement: Don't allow sites use info about your screens to open and place windows
Scroll down to “Content” . . . and set:
Pop-ups and redirects: Don't allow sites to send pop-ups or use redirects
‘And for good measure’ - go to: brave://settings/security and Disable : Use secure DNS
289wk
May 30, 2022, 2:49pm
5
system
Closed
June 29, 2022, 2:49pm
6
