ChatGPT lag/stability issues
Description of the issue: In the last few days, When working in ChatGPT, I’m experiencing severe lag issues. Chats often now take several minutes to load. Voice to text hangs or even fails completely. When I switch to other browsers, there is no issue. It seems similar to trying to view Facebook on Brave.
  1. Open Brave (Windows, Desktop)
  2. Log into Chat GPT account, and start using it. It will work for a few minutes and then it slows down
Expected result: Chat GPT chats and projects take minutes to load, entering instruction in chats sometimes fail or take minutes to register, responses fail, and text to voice becomes unstable and unusable. The issue is not occurring in other browsers.
Brave Version( check About Brave): Brave 1.100.58 (Official Build) (64-bit)
There have been a few previous reports of ChatGPT experiencing loading and voice/dictation problems specifically in Brave, even when working normally in other browsers.
It would be useful to narrow down whether this is related to your Brave profile or a wider compatibility issue.
Have you tried opening ChatGPT in a Private Window to see whether the same slowdown occurs there?
Also, does it happen with brand-new chats as well as existing conversations, or is it mainly with longer chats and projects?
There’s a previous discussion about ChatGPT voice and dictation issues in Brave here:
@PeteS
Take a look at:
‘Opus, Grok, GPT Returning empty or cut off responses - #3 by 289wk’
‘Most Leo models still not working; hanging on thinking with no output or cutoff output - #6 by 289wk’
‘Brave Built Something They Didn't Figure On - #20 by 289wk’
So just a heads up, I had a incredibly long reply and then decided to actually run it through ChatGPT (partially to see if it would still work after it seemed to be loading again for me). Below is how ChatGPT suggest I write to you and also provided information itself based on error logs and other details I provided.
@PeteS, which other browsers have you tried?
I’ve been experiencing what sounds like the same problem, except it’s happening across all four browsers I’ve tested: Brave, Chrome, Edge, and Firefox, all on Windows.
The issue has been intermittent. There are short periods when ChatGPT works perfectly, making me think the problem has been resolved, only for everything to become unusable again a few minutes later.
What I’ve been experiencing
When I open ChatGPT, the website itself generally loads, but the actual functionality frequently stops working.
  • Conversations won’t open. Clicking an existing conversation, recent chat, or project often does absolutely nothing.
  • Image uploads get stuck. When I try uploading an image, it remains a gray placeholder and never finishes uploading.
  • Messages won’t send. I can sometimes type a message, but the submit button remains grayed out. Other times, the button becomes available, but submitting the message causes the conversation to hang indefinitely without a response.
  • Failed messages aren’t saved. If I refresh the page or open ChatGPT in another browser, there’s no indication that the attempted message or upload ever existed.
  • The problem comes and goes. Sometimes everything suddenly starts working again without me changing anything.
I’ve been using ChatGPT extensively for a project in which it’s helping me develop an application. Initially, I suspected that the complexity or length of those conversations might be contributing to the problem, since ordinary chats sometimes appeared to work better.
However, I’ve since experienced the same failures across other conversations and projects. At this point, I’m not convinced that the application development project itself is responsible.
Other people are reporting similar problems
I’ve found several discussions describing ChatGPT becoming unresponsive, failing to load conversations, or interrupting responses:
  1. Conversations terminate early, fail to load, and interrupt responses across browsers and Android
  2. ChatGPT Web frequently shows “Unable to load GPT conversation” after the recent UI update
  3. Reddit discussion about a workaround for ChatGPT website problems
  4. Recurring ChatGPT loading failures, stream errors, and stuck tasks
OpenAI’s service status
Another interesting observation is OpenAI’s own status history:
Although the current status may indicate that systems are operational, the incident history contains numerous yellow, orange, and red indicators.
There was also a reported incident on November 18 involving elevated ChatGPT conversation errors, particularly affecting Free and Go users.
I’m a ChatGPT Plus subscriber, so I can’t say whether that specific incident explains what I’m experiencing, but the symptoms are certainly similar.
A particularly interesting observation
While writing this reply on November 18, I repeatedly tested ChatGPT between approximately 6:40 PM and 6:49 PM Eastern Time.
During that period, I couldn’t get my project to load properly in either Brave or Firefox. I tried repeatedly without success.
Then, just as I was preparing to post this reply, I tested both browsers again.
Suddenly, the conversations loaded normally in both browsers.
I hadn’t changed any settings, cleared my cache, restarted the browsers, or done anything else to resolve the issue.
That intermittent behavior is one of the biggest reasons I’m suspicious that the problem is on OpenAI’s side rather than being caused by Brave.
What the browser’s developer console shows
I also captured several errors from the browser’s developer console and asked ChatGPT to help interpret them.
Among the errors were:
Timeout of 10000ms expired
Network requests were timing out after 10 seconds.
net::ERR_HTTP2_PROTOCOL_ERROR
The browser was encountering errors involving HTTP/2 communication.
There were also failed requests involving ChatGPT’s conversation endpoints, including:
  • /backend-api/.../conversation/prepare
  • /backend-api/.../conversation/finalize
ChatGPT explained that these errors suggest actual communication failures during conversation-related requests, rather than simply a problem with the browser rendering the page.
It also pointed out that these errors don’t conclusively identify the cause. They could involve OpenAI’s servers, network infrastructure, or something between the browser and the service.
My conclusion
I’m increasingly inclined to believe this is a ChatGPT service or backend issue, possibly involving intermittent failures that aren’t reflected in the overall service status.
The fact that it’s happening in Brave, Chrome, Edge, and Firefox, combined with other users reporting similar symptoms and the periods where everything suddenly works again, makes a Brave-specific bug seem less likely in my situation.
Of course, that doesn’t necessarily mean we’re experiencing the exact same underlying issue.
I’m particularly curious whether anyone else experiencing this has tried multiple browsers and whether their failures also come and go without any changes on their end.
Gemini also kind of agrees.
OpenAI / Cloudflare Edge Hiccups (Server-Side): net::ERR_HTTP2_PROTOCOL_ERROR frequently triggers when OpenAI’s backend or Cloudflare’s edge node drops an active HTTP/2 stream mid-response, sends a malformed header, or hits an upstream timeout during high load or a partial service degradation. Because the Statsig telemetry endpoint (/ces/v1/rgstr) is timing out at the exact same moment as the core /backend-api/ endpoints, an upstream OpenAI/Cloudflare routing issue is a strong suspect.
So not quite sure what to say. Sorry, message before still was long. But was hoping it could be helpful. It’s annoying as heck but can say as ChatGPT has been acting up more frequently, it has been driving me more to spend more time on Gemini and others.
All that said, I’d be curious to know more of which browsers you are using and when it is working on the others, if you test to see if it’s working on Brave again as well. Kind of to get more of the overall picture.
Thanks for this. My experience is similar to yours - almost. All of the symptoms you’re experiencing are the same as mine, with the addition that voice to text chats hang and/or fail. I’m also developing an app, so fairly extensive use. Where my experience differs considerably is the browsers. I’m experiencing this problem exclusively with Brave, which is my primary browser. I tested it on Firefox and Edge and had no issues whatsoever. I settled on Firefox, and it has been running smoothly ever since. I keep switching back to Brave, to test it, and the problems recur if I use for more than a few minutes. It is also intermittent to some extent - although at this point it’s problematic more often than not. It’s similar to the type of behaviour I see if I try and load FB into Brave - although with FB it’s markedly worse, and quite constant.
I tried opening in a private window. The same issues recurred. It happens with both new chats (message and/or upload won’t send) and existing chats, which in addition to that can sometimes take upwards of 5 minutes for the chats to load. And while they are loading, there is no using ChatGPT at all - nothing works.
Thanks, that’s helpful. I wouldn’t rule out an issue on OpenAI’s side either, as I’ve personally experienced similar ChatGPT problems across multiple browsers.
The Facebook comparison is interesting, though. Have you tried turning Brave Shields off specifically for ChatGPT to see if it makes any difference? Just click the Shields lion icon in the address bar while on ChatGPT and toggle Shields down for that site.
It would be useful to see whether that changes anything.
