Cant click on right side of screen Ubuntu 23.04
Unable to click on anything to the right of the PLUS, AND to the right of the jigsaw extensions icon, AND the ‘Other bookmarks’.
Ubuntu 23.04-
Linux 6.2.0-20-generic #20-Ubuntu SMP PREEMPT_DYNAMIC Thu Apr 6 07:48:48 UTC 2023 x86_64 x86_64 x86_64 GNU/Linux
Brave: v1.52.126
HP 27-a210 All-In-One AIO
1920x1080
If i shrink the browser using WIN-Down, then I can interact with all buttons. But in normal max mode, I can’t.
Still an issue with this.
@phelix Always have to start at some of the default troubleshooting steps. Haven’t seen you mention trying it. Do a step and if you can replicate the issue, go to the next step.
  1. Try opening in a private window. Does it persist?
  2. Create a new browser profile. Don’t change settings and make sure you add no extensions. Does the issue still occur?
  3. Can you install Brave Beta and/or Brave Nightly and see if it replicates there?
  4. Can you test on Chrome? Curious to see if happens on that.
  5. Lastly, do you see this happen with anything else on your device?
  1. Still exists in private mode ctrl-shft-n
  2. same problem in new profile. no extensions
  3. I’ll try that.
  4. happens on chrome also.
  5. It’s only chrome and brave. I have to minimize the browser to be able to interact with the top right area.
Same problems in beta.
If so, sounds like a chromium issue which may need to be fixed upstream. I’m going to tag @Mattches on this and see if he can try to look into it or what he’ll advise you
Weirdly, it was Anydesk.
Uninstalled, rebooted, fixed.
Glad to hear you figured it out. I knew support would eventually be getting to you. What I didn’t think about is today is actually Juneteenth, a holiday signed into place by Joe Biden a couple years ago. Support doesn’t work on (USA) federal holidays or weekends. So yeah, would be why we have some delays in responses today, lol.
