Right click on tab does nothing on Ubuntu 20
Description of the issue: Right clicking on a tab shows no context menu
  1. Install Ubuntu 20
  2. Install Brave
  3. Right click on a tab
Expected result: Context menu should appear allowing tab pinning etc.
Brave Version( check About Brave): Version 1.23.75 Chromium: 90.0.4430.93 (Official Build) (64-bit)
This also occurs in all Chromium-based browsers I tried, including Chrome and Vivaldi, so it’s likely an upstream issue.
Installing the synaptics driver may have fixed this for me (reference). I’m not sure if that’s the case, but after a reboot all is well.
