Brave Shields icon not working with Duet enabled
Description of the issue: When you enable Chrome Duet in the Brave android app, the Shields icon doesn’t open the Shields panel.
Steps to Reproduce:
  1. Go to chrome://flags on the Android app (possibly also iOS, but can’t confirm)
  2. Search for “duet”, and select enable in the drop-down menu.
  3. Restart the app completely twice.
Actual Result: Pressing the Shields icon doesn’t do anything
Expected result: Pressing the Shields icon should open the Shields panel
Reproduces how often: Tried disabling and re-enabling the flag, bug still present, so 100%
Brave Version(about:brave): 1.0.77
Mobile Device details: Lenovo P2a42
Android/iOS Version: Android 7.0
Thanks for reporting @dyamicfleyer,
It’s a known issue. Logged here https://github.com/brave/browser-android-tabs/issues/900
The team also working on a new design for Android that have bar on the bottom. :wink:
Thanks,
:slight_smile:
