I’ve used Lastpass previously, Its just treated like Chrome. Blaming Brave is just an easy target. Nothing stopping Lastpass working on Brave, like any other password manager.
I have similar problems: Whenever I close Brave and restart the browser I am logged out of LastPass. I followed the advice to disable the “Share log in state between browsers” option in the LP extension. This does not help.
Chrome in contrast works without problems.
And both browsers are freshly installed on a fresh installation of Ubuntu Studio 24.04 Linux.
You’ve used LP in the past while I use it every single day since 2009 & you are telling me you are right & I’m wrong AND it’s working fine on Chrome, but it’s not Brave, it’s me lying.
I don’t have my masterpass handy; but I got up to the install option. And unlocking the account sent to my email
What exactly is the issue? Not a last pass user here, I can re-create a new account since I misplaced my master password. But on the surface it looks fine so far.
Have Logged in, and its not restarting the PC, maybe its unrelated to LP. Maybe scan for malware or check that its not overheating/unstable overclock/buggy ram.
Could always confirm by installing LP/Brave on a different PC to confirm thats this is the case.
That’s possible, I just closed Brave and re-opened, and LastPass is still logged in. That said, I thought I had seen the same behavior as you previously after a Brave update (and restart), but it definitely isn’t happening at the moment (on MacOS).
