Hello everyone, I have a problem with this browser. I want to block pornographic sites from this browser. How I do that? Thank you.
@Ronaldogn7 depends on how severely and situation. If it’s just for you, go into Shields via Settings → Shields and then choose Content Filtering. From there you can choose Blocklists Anti-Porn
That’s at least a simpler way, though disabling Shields will disable that block. But if it’s just a basic protection you want, then that’s what you’d do.
For more in-depth blocking, you would need to adjust the DNS you’re using, such as is discussed at https://blog.cloudflare.com/introducing-1-1-1-1-for-families/
@Ronaldogn7 anything beyond that is tough to answer because you chose not to include the template and did not provide any details at all. What makes it even more challenging is you labeled yours as android and ios, both of which are very different from each other in capabilities and settings. So you need to be much more specific on what you’re needing help with.
