Asuracomic not showing manga
Exact URL of the website in question: Asuracomic
Screenshot of the ad as it appears in Brave: The opposite happen, there is no ads & the pages is also gone, but without AdBlock I can read the manga back.
Private Windows
Did the issue present with default Shields settings? (yes)
Does the site function as expected when Shields are turned off? Yes
Does the ad appear when using a Private window as well? (no)
What OS are you using when you see the ad? I’m using Windows 11
Brave version (check About Brave): v1.82.170
You’re Blocking scripts in shields, which is why its breaking. Disable that
I can’t disable it, in the Shields setting it even turned off.
For some reason it automatically on when I go into Asura, but I can turn it off in Private Windows
@Nulleb you turned it on in the site settings, turn it off there as well. It sounds like you’re just trying to change your global settings, but that wouldn’t override your site specific ones
Just toggle that off.
I tried
Recording 2025-09-23 082151-low-quality
Try doing a reset; brave://settings/reset
That fixed it, thanks!
