Aniworld ad popup block not working
Description of the issue**: aniworld bypasses the ad popup / redirector block**
Exact URL of the website in question**: aniworld.to**
aggressive ad tracker block.
With shields down the site works like it would on any other browser. Lots of ads and redirects
The Site won’t work on private mode. Better said, the embedded video player will not work / show the play button.
I’m using Android with Brave nightly Version 1.94.32
Just update the lists, a fix went out upstream.
Unbelievable how fix you got it to work.
Not even an hour later it worked.
How comes the brave support is that quick?
Thanks for the quick fix.
