I need help because the ad blocker isn't working as well as it should
Good day everyone!
At a website where I am often I am still redirected to the evil websites. The blocking system is crazy at the moment, yesterday I was never redirected but was able to watch videos on this legal website comfortably. You have to tap on videos to see them and when you tap you will be redirected to other websites. But thanks to your blocker, I can watch it without being forwarded. But today you can almost always get through to the other websites, the protection is still there but not as strong as yesterday. Yesterday no problems today problems. Even getting notifications from another app telling me that these websites where I go almost all the time are dangerous. Thanks to this app and your blocking, I’m almost never at risk. Please fix this bug or this problem. Please check what is the reason for this. I have ad blocking on aggressive. Pls help me. I love brave.
@Nentosmentosato I’m going to share a few links that might help. Before that though, please check out Tips for posting and consider it before you post in the future. You placed this in the wrong category (at least initially, I see it moved categories as I was typing this) and did not include a lot of information that would be needed to try to help you. Those tips should be able to help with some guidelines.
That said, I think these two articles below may also help. Try to check your settings against it and if you still have issues, at least check out the troubleshooting steps. It also advises you of some of the information needed in order to try to help you.
I I’m new here and completely confused about this website. my English is not so good I often use translators to get by otherwise I’m going crazy with so many posts and links.
@Nentosmentosato You are fine. I hope not taking anything negative. I have created small guides to try to help people understand things.
What is tough in posts like yours is that without knowing which type of device you’re using, it can be difficult to make suggestions. Also, the way it is phrased, it is hard to know if you are experiencing issues on all sites or only some.
Main thing is just hoping to hear more details from you. But in the meanwhile, was also letting you see potentially things that could help.
Btw, not sure which language you speak, but if it’s a well known one, feel free to type in your primary language and I’ll use a translator. It might be easier for you that way.
I speak German, and I have a android handy Modell: moto g⁸ the website i use often is called aniworld. Android version 11
@Nentosmentosato Okay. Lassen Sie mich die Dinge also langsamer angehen und sehen, ob wir ein besseres Tempo vorlegen können. Tritt das Problem auf allen Websites auf oder nur auf bestimmten Websites? Können Sie Links zu einer Website angeben, auf der die Probleme auftreten?
Bei Aniworld kommt man kurz zur ne andere Webseite aber der Blocker ist schon aktiv und bewahrt mich davor aber man sieht das man weitergeleitet wird. Also das ist bei aniworld überall so mit Weiterleitung und Werbungen, man muss nur zurück zwischen um wieder bei Aniworld zu sein, Trotzdem passiert das nach der Zeit wieder mit der Weiterleitungen und Werbungen. aber seit dem man diesen Brave Browser nutzt war das nicht mehr so außer komischer Weise heute. dieses hier brave://adblock mit denn filtern, habe ich da ein paar angemacht Aber hat nicht
viel dazu getragen, um diese weiterleitung zu besiegen. alle Versionen sind aktualisiert. Ich muss nix runterladen Weil alles auf dem neusten Stand ist. Ein Link zur einer Folge wo ich gerade schaue. Ein Problem von vielen Videos mit diesen Weiterleiten und adblocker, denn ad blocker nutze ich gerne. die Weiterleitung kommt wenn ich auf das Video tippe. Gestern war alles frei von Weiterleitungen. Als ich das erste Mal genutzt habe.
https://aniworld.to/anime/stream/one-piece/staffel-1/episode-31
@Nentosmentosato Ich verstehe. Als ich gerade getestet habe, hatte ich Probleme mit VOE, aber es gab keine Probleme mit Vidoza oder Streamtape. Es scheint, als ob VOE ein Overlay zu den eigenen Servern aufbaut, um zu versuchen, die Tracker und die Werbung den Leuten aufzuzwingen. Könnten Sie mir einen Gefallen tun und das Video stattdessen mit einem dieser Spiegel/Server testen? Sagen Sie mir, ob Sie das gleiche Problem haben oder ob es sich löst.
Bei denn anderen Funktioniert es also hab paar mal getippt und scheint wohl zu halten. Voe hatte gestern aber nicht diese Probleme, gestern konnte ich mit voe alles mögliche anschauen ohne das irgend eine Weiterleitung kam. Voe ist bei mir auf Platz eins weil ich da mehr denn hellen Balken unten sehen kann bei denn anderen sieht man das nicht so ob das Video jetzt funktioniert und gut läuft oder wieder am laden ist. Bei dem Streamtape braucht es mehrere Sekunden bis da ein Balken kommt. Und das macht mir oft ne Unsicherheit.
@Nentosmentosato Das Schwierige an der Arbeit mit Filtern für diese Websites ist, dass sie nur eine kurze Zeitspanne überdauern. Die Websites verwenden in der Regel so genannte Rolling Ad Server. Diese bleiben nur für eine begrenzte Zeit aktiv und werden dann wieder gewechselt. Adblock-Filter müssen sich ständig über diese Websites informieren und sie hinzufügen. Es gibt jedoch keine Möglichkeit, sie zu 100 % zu stoppen. Das gilt vor allem, wenn Websites kreativ werden und beispielsweise Dinge in den Webplayer einbauen, bei denen die einzige Möglichkeit, die Werbung zu stoppen, darin besteht, den Player zu zerstören.
Ich werde eine kurze Zusammenfassung erstellen und jemanden von Brave kontaktieren, um zu sehen, ob er helfen kann. Aber ich weiß, dass sie sagen, dass diese Art von Websites und Problemen schwieriger zu handhaben sind und keine Versprechungen im Allgemeinen gemacht werden können. Vielleicht muss man nur einige der verschiedenen Player ausprobieren, so wie ich Streamtape und Vidoza erwähnt habe, die im Moment gut zu funktionieren scheinen.
@fanboynz Can you confirm? Issue is anime site, which is https://aniworld.to/anime/stream/one-piece/staffel-1/episode-31
If you got to play the video, especially using VOE player, it has a pop-up ad appear and/or redirects. I think you said these things are difficult to really do much with, but want to see your thoughts. I do know when tested Streamtape and Vidoza, the issue doesn’t seem to happen. So not sure if “solution” is to avoid the one video player or if Shields are able to be adjusted?
In Ordnung wäre nicht enttäuscht wenn das immer noch da ist.
Brave doesn’t support $popup, which is used a lot by lists. Brave is still missing some few features but there are features Brave adblocker has that can workaround that limitation.
You can add this rules to brave://adblock to stop the popup, which is better in this case than $popup, because it stops the popup from happening, instead of opening and then closing it.
availedsmallest.com##+js(nowoif)
and you can also add ||underwearsourorb.com^ since that is the one that is that ones that get popped up, but it’s just as a fallback, since nowoif should take care of things for now, until it gets fixed properly by Brave Team.
If you want the same behavior as $popup (which equals to opening popup and then closing the site), you can use underwearsourorb.com##+js(window-close-if, /^/) But you need to remove ||underwearsourorb.com^ because that rule will block completely the document from loading by the browser, so nothing like JS or anything is able to work unless you hit ‘proceed’.
But yeah, window-close-if will just do the same as $popup, probably not as good as $popup does it, but in terms of what it does, popup applies the same window.close() as window-close-if, while nowoif does a window.open in their scriptlet.
https://availedsmallest.com/e/efzdair6errn
No popups seen here
@Nentosmentosato Ich bin mir nicht sicher, ob sie etwas zu den Filtern hinzugefügt haben, das das Problem bereits behebt, oder ob die Anzeigenserver auf etwas anderes umgestellt haben. Als ich jedoch gerade wieder getestet habe, scheint das Problem behoben zu sein. Bitte teilen Sie uns mit, wenn Sie irgendwelche Probleme haben. Ansonsten scheint es im Moment gut zu sein.
