The issue as described in Android: Enpass autofill not working / wrong URL handover still persists for current (1.1.2) versions of Brave on Android.
Autofill in Enpass works with Chrome as the URL is handed over to Enpass, thus selecting only matching passwords in Enpass.
With Brave the only thing handed over to Enpass is the application name “Brave” and no URL. You therefore have to manually select the proper entry and match this entry to the “Brave” app in Enpass to make it work on future uses.
Brave should behave the same way Chrome does and hand over the proper URL instead. Firefox on Android also handles this properly.
Steps to test this can be found at Android: Enpass autofill not working / wrong URL handover
