Hi, I have a autofill passwords problem with Brave 1.61.104. It is not working on some banking sites and on private https sites using autosigned certificates.
The url is identical with the saved ones (but some are imported)
Open a site with saved credentials. Example: https://business.ing.ro/ or https://login.bcr.ro/users/login
Brave does not suggest any credentials
Suggest credentials
Always
Not working on Windows 10 and Windows 11, Brave 1.61.104, Chromium 120.0.6099.115
Works on Android 12, Brave 1.60.118, chromium 119.0.6045.163
For the same sites Chrome or Firefox are suggesting correct credentials without problems
