hello , i havve problem i don’t know if for all brave users or just me , but youtube is not working until i turn brave shields off , idk what the problem is but i hope it will be fixed , thank you brave for ur great app .
Cuz if this didn’t help, im not gonna do lil by lil and just throw everything at once because I’ll prepare myself more info for this one.
thanks , i had it checked but still same issue it works only in private window or when i turn the shield off
Alright.
• Try clearing up cookies from YouTube on non-incognito-mode tab.
• Try doing the same on Google Chrome, Firefox, Edge, or Opera Browser (Highly Recommended same - Chromium Browsers).
• Check if you have any Ad Blockers enabled - this has chances to cause issues that vary by visual but all end up from same field.
• Make sure your WiFi is minimally fine (e.g, at least 2 Sticks).
Also i would love to see a screenshot of how exactly it appears to you as not working thx.
Its very likely that you are using an Ad Blocker, check integrations that you have installed at Brave - or apps like an AdBlocker that does the Ad Blocks for Web.
Theres a way smaller chance that it all comes down to your DNS
