Youtube player problem
I am having a problem recently with brave, I had being using it for over a year and never seem this happening, basically after I opened a youtube video, the whole player looks weird with a second progress bar and a weird overlay with an X on the side (like show on the image)
I am using the latest the latest version on a Windows 10, this started on the beginning of the month and it is really annoying that out of nowhere this started happening.
bonjour
vous avez essayé avec un autre navigateur ?
crdlt
Yeah, other browsers work fine, I tested on edge and chrome, only brave seems to have this problem.
Can you share a short screen recording of what it looks like when you go to youtube and select a video to stream so I can get a better idea of what you’re seeing?
Bonjour
Avant de tout desinstaller..tenter de creer un autre profil brave.parce qu apparement ca vient de lui…et testez..
Crdlt
