Youtube comment section is disable while using Brave
Just as title “留言功能已停用“means “comment section is disabled“
But it come back after I refresh the page. And it only happened on this youtube account. Another works just fine.
The same by me
Well, that’s a new one.
Can confirm there should be a comment section. Pulled the same video as shown in the original post, and it’s not locked, there should be comments.
(I’m on Brave however, and it worked, so I might leave this one to @fanboynz as I’m not entirely sure how that can happen, same video, but one of us can see comments, and the other sees it as if it’s locked, when it’s not?)
For reference, the video in the original post is here: https://youtu.be/HkMykatgbPI
(That way we all look at the same URL specifically.)
Is this still an issue? @MasterLink
I’m not the one seeing the issue, @atix83518 and @Ravn73 seemingly are. I can confirm the video posted in the top should have comments, so I don’t know why they see it as disabled.
uBO devs have been testing/improving youtube today, possibly an older fix caused the no comments.
yes i am on Brave 1.87.186 (Official Build) (64-bit) chromium: 145.0.7632.45
initially comments are turned off but when i refresh its come back like normal
Update the lists in brave://settings/shields/filters then refresh YT, also ensure you’re not using other adblock extensions.
Hey I tried to update list, delete cookies, and almost everything, and still not working yesterday. But…today it’s fixed!!(for me) thx for your replies!!
