X/Twitter not loading past like 4-6 posts or comments
ddd|690x368
Basically whenever I go on twitter/x i can only see the first 4 posts and then it stops loading new ones. When i switch to a different browser it works perfectly fine.
https://x.com/home
no
no it doesnt work when shields are off either
no
the site works fine on chrome
newest brave version
Can you please try clearing cache/site data for x.com and see if this resolves the issue? Easiest way to do this would be to visit x.com, click the “tune” icon in the address bar:
Then click Site settings --> Delete data:
Refresh the page then test again.
tried it and im still having the issue
Same for me but i cannot see anything it says “Something went wrong. Try reloading.”, Ive done what was written above and didnt help. I logged into Chrome and everything worked fine.
Can you both please try launching a Guest profile (Menu --> More tools --> Guest profile), closing your original profile window (so that only the guest profile is open) and visiting Twitter and see if you get the same results?
Tested and it worked with guest profile.
Have you tried clearing cache/site data for Twitter as described in my previous reply?
done it several times,i dont really use any extensions only
Can you please disable those extensions and try logging into Twitter and testing again?
I figured it out yeah turns out it was a single extension that breaks the entire site which is weird because on any other browser it still works fine with it on. the extension btw was.
disabled everything, still nothing. how can i clean install brave? that might helps
X works just fine for me, loads comments, posts, without issue, on the latest stable Brave version as well.
As far as clean install, you’ll just uninstall Brave, download the latest executable, and reinstall.
First, I would try just un/reinstalling the app without deleting your browsing data. However, if the issue is contained within your profile it is likely to still occur, in which case you would need to uninstall the application as well as your browsing data (you should see a prompt asking whether or not you want to do so during the uninstall process).
i did absolutely nothing and it fixed itself somehow, well thanks anyways
