yrona
November 14, 2023, 3:15pm
1
I have two machines running POP OS. Since the most recent update of brave, the minimize window and close window buttons are displaced down into the main body of the browser. This is a constant condition and can be reproduced by simply running Brave.
Brave Version:
Version 1.60.110 Chromium: 119.0.6045.105 (Official Build) unknown (64-bit)
OS:
POP OS 22.04 LTS
Gnome Version: 42.9
Windowing System: X11
This is a known issue that the team is working on addressing presently:
opened 05:45PM - 08 Nov 23 UTC
OS/Linux
priority/P2
QA/Yes
release-notes/exclude
OS/Desktop
feature/vertical-tabs
<!-- Have you searched for similar issues? Before submitting this issue, please … check the open issues and add a note before logging a new issue.
PLEASE USE THE TEMPLATE BELOW TO PROVIDE INFORMATION ABOUT THE ISSUE.
INSUFFICIENT INFO WILL GET THE ISSUE CLOSED. IT WILL ONLY BE REOPENED AFTER SUFFICIENT INFO IS PROVIDED-->
## Description
Follow-up to https://github.com/brave/brave-browser/issues/33928 which showed a similar misalignment when the title bar was hidden, as it is by default on the more popular desktop environments.
## Steps to Reproduce
1. Open settings (brave://settings in the address bar)
2. Search for 'tab'
3. Click to enable 'Use vertical tabs'
4. Click to select 'Show title bar'
## Actual result:
Close button and other window decorations are drawn half on the toolbar, half on the title bar, neither aligned with the other toolbar buttons nor in the expected place in the title bar.
## Expected result:
Close button (and min/max buttons, if the desktop theme includes them) should be aligned with the other toolbar buttons as they are when the title bar is not shown
## Reproduces how often:
Always. Tried both Fedora 39 (gnome-shell) and Pop OS 22.04.
## Brave version (brave://version info)
1.62.32 Chromium: 119.0.6045.105 (Official Build) nightly (64-bit)
## Version/Channel Information:
- Can you reproduce this issue with the current release? yes
- Can you reproduce this issue with the beta channel? yes
- Can you reproduce this issue with the nightly channel? yes
## Other Additional Information:
- Does the issue resolve itself when disabling Brave Shields?
- Does the issue resolve itself when disabling Brave Rewards?
- Is the issue reproducible on the latest version of Chrome?
## Miscellaneous Information:
yrona
November 15, 2023, 3:38pm
3
That’s good to know. I apologize for the duplicate submission; I had searched using the wrong terms, and never saw the original submission.
No worries! Hope to have the issue fixed asap.
