Menu buttons overlapping with system buttons in horizontal tabs
Description of the issue: As you can see in the attached screenshot, whenever i turn on vertical tab, the browser menu buttons(menu, extensions, downloads) and the system app menu buttons(minimize,maximize,close) gets overlapped. it’s works fine on horizontal tab mode.
Ubuntu 26.04 LTS
GNOME Shell 50.1
  1. Turning on vertical tab.
  2. Open new tabs
Expected result: Menu buttons placed a bit on the left proportional to minimize buttons.
Brave Version: Brave 1.89.143 (Official Build) (64-bit)
Chromium: 147.0.7727.11
Additional Information: here’s a screenshot. look at top right corner, the buttons are overlapped.
I don’t have Ubuntu currently installed at the moment, but I used to on a VM. Does Brave settings have an option to show title bar in vertical tabs?
Also, do you have any Ubuntu customizations, like custom window managers etc.?
Yes, there is the option for “show title bar”. I have tweaked them. but it’s still overlapped.
No, i am not using any customizations that may alter window managements or anything like that.
I’ll ask @Mattches to help you further with tech support. It’s likely a Brave issue.
Update: I have tried to turn on “show title bar” after restarting my laptop and the system menu buttons have moved up and the overlapping problem seems to be solved in this mode. but if i turn it off, everything seems to the previous situation.
Thanks a lot for looking into it.
Please mark this as the solution, and glad that this worked for you!
yes, i have marked it as solution. Still it’s half the solution. Problem still arises if i turn off “show title bar”. Hopefully the devs will look into it.
First thing I would recommend is updating your browser to the latest build – it looks like you’re a few releases behind.
Additionally it sounds very similar to some of the other open issues we have:
