So I know that Brave team is working on a sidebar (https://www.reddit.com/r/brave_browser/comments/l1xb2x/brave_team_is_working_on_a_sidebar/ ) But when will it be finished? I would like to see the feature and I tested it on Brave Nightly. I did only find ONE bug and that bug was fixed too. I would like to see the feature being added and Brave developers are going in the right direction.
@anon23769284 ,
Pleased to hear your excitement. You can actually see the progress of the feature by following the issue linked below:
opened 11:22PM - 26 Mar 21 UTC
OS/Desktop
feature/sidebar
priority/P3
## Description
We have a Sidebar that is available in Nightly which can be ena… bled via brave://flags/#sidebar
Some specific issues have been captured and labeled with [feature/sidebar](https://github.com/brave/brave-browser/labels/feature%2Fsidebar)
This issue is intended to track work required before we can release an MVP (minimal viable product) of sidebar
## P1
- [ ] Sidebar item missing selected state when open in the current tab (Need more discussion for this item)
- [x] Show “Add to sidebar” menu on hover (https://github.com/brave/brave-browser/issues/15713)
- [x] Clicking a sidebar item should open in the current tab, not new tab (https://github.com/brave/brave-browser/issues/15084)
- [x] Clicking a sidebar item that is already open in any tab/window should bring that into focus instead of opening another tab (https://github.com/brave/brave-browser/issues/15084)
- [x] Settings button in sidebar does not work (https://github.com/brave/brave-browser/issues/15084)
- [x] Show sidebar options don’t work (https://github.com/brave/brave-browser/issues/15592)
- [x] Drag to reorder sidebar items (https://github.com/brave/brave-browser/issues/15135)
- [ ] Bookmarks in sidebar is empty (https://github.com/brave/brave-browser/issues/14950)
- [ ] Responsive History - Settings ribbon needs to be hidden
- [ ] Responsive Bookmarks - Settings ribbon needs to be hidden
## P2
- [ ] Clicks and hold on the sidebar item should show options (https://github.com/brave/brave-browser/issues/16017)
- [ ] Drag a sidebar icon off to remove it
- [x] “Added to sidebar” tooltip should be limited to 3 times; not forever. (https://github.com/brave/brave-browser/issues/16018)
- [ ] Need focus states
## P3
- [ ] Sidebar options menu should use Brave menu component (applies to all sidebar icon menus and show sidebar menu)
- [ ] Add to sidebar by dragging the tab into the sidebar
- [ ] Add to sidebar by dragging the site information (lock) icon in the URL bar into the sidebar
- [ ] Incorrect typography treatments on “Add to Sidebar” menu
- [ ] Resizable sidebar panel
- [ ] Show sidebar on top of webview rather than resizing the webview (#16059)
## BUG
- [ ] Incorrect sidebar mouse event detect area with On click option (https://github.com/brave/brave-browser/issues/15745)
- [ ] Sidebar event dectect area is visible in full screen (https://github.com/brave/brave-browser/issues/16157)
- [ ] Sidebar UI should be hidden only when tab-initiated full screen (https://github.com/brave/brave-browser/issues/16160)
