Weird, hard-to-read fonts
Weird, hard-readable fonts appear in browser, expect the visited links - those are normal.
Turning Shields on and off doesn’t work. Changing any font settings doesn’t work. Uninstalling/reinstalling Brave doesn’t work.
Thx!
Version: 1.67.123 Chromium: 126.0.6478.126 (Official Build) (64-bit)
on Windows 10
meteo
Hello - Is this an issue if you create a new test profile? Thanks for confirming.
No, i have been using Brave for months with the same profile, but the error is new.
Do you have any extensions installed recently? Check your fonts here brave://settings/fonts
No extensions at all.
Font settings are default (i think):
standard & serif: Times New Roman
sans serif: Arial
fixed: Consolas
math: Cambria Math
I know I’ve seen this issue before — @odinn can you try the solution suggested here and tell me if it resolves the issue?
It’s already checked in. Checking in and out and restart doesn’t solve the problem.
Could also bee a ClearType issue:
Ok, i’ve find the solution. There was an extension called OpenDyslexic in a Chrome browser in the same computer, and Brave get this extension somehow today. I’ve disabled it, and the fonts are readable again.
Thanks for everyone.
