When using Vertical Tabs and positioning the browser window on the right of the screen, the Tab Group dialog is partially hidden
- Create a new profile
- Set Vertical Tabs on
- Snap the window to the right side of the screen
- Open some tabs
- Add tabs to a Tab Group
- Observe the Tab Group dialog
The dialog should be fully visible
Brave Version:
Version 1.74.48 Chromium: 132.0.6834.83 (Official Build) (64-bit)
This has been a bug for a long time, not just the latest version.
Running on Fedora 41 with Gnome
In the screenshots below, the dialog extends slightly beyond the edge of the window. I think this is because the display server adds a shadow and reports the left edge of the window as being where the shadow ends. When there is screen space on the left of the window, the dialog appears to be aligned with the right of the tab strip.
With the tab strip not pinned:
With the tab strip pinned:
With the window snapped to the left of the screen:
