I use vertical tabs and I like the fact that I can hide them, it’s convenient while watching videos streams etc, however, if I have two windows of Brave opened, and I hide the tabs on one of the window, it’ll also hide on the other window, they should work independently.
Related topics
| Vertical Tabs are not visible | 0 | 282 | July 4, 2023 | |
| Allow separate windows to have different settings for vertical and horizontal tabs | 0 | 249 | January 22, 2024 | |
| Disconnect Minimize Tabs function between separate Brave windows | 1 | 47 | April 1, 2026 | |
| Vertical tab bar frequently found expanded when returning to a Brave window where I had previously left it collapsed | 13 | 346 | September 14, 2026 | |
| Vertical Tabs status (min/max/hidden) *PER* window | 0 | 201 | February 19, 2024 | |
| Vertical tab glitch when switching back to normal tabs | 0 | 447 | September 13, 2023 | |
| Merging windows with vertical tabs | 0 | 86 | October 15, 2025 | |
| Brave pages bug | 3 | 126 | October 7, 2024 |
