Vertical Tabs Not Working After Hovering Over Toolbar
This is a bug that happens to the vertical tabs when they are set to fully hidden. If your mouse comes into contact with the toolbar at any point, Brave Browser disallows you to hover into your vertical tabs. This is a bug that I’ve reported before, linked here: Vertical tabs not showing after hovering over the toolbar It was fixed, but it has recently resurfaced.
  1. Open Brave Browser
  2. Hover over toolbar
  3. Hover over hidden vertical tabs
Expected result: Vertical tabs should expand
Brave Version( 1.95.104 ):
Additional Information: Like before in the previous bug report, you need to be in fullscreen. Additionally there is another vertical tab bug that is more enigmatic; it’s a bug where if you go back and forth within the vertical tabs and the window, whatever tabs you were hovering over will appear as tho you’re still hovering over them.
I cannot reproduce this one but also I don’t think I understand the behavior – you’re saying that vertical tabs should not expand on hover…?
Sorry, I thought the “expected result” actually meant “what will be happening” not what it should look like once fixed lol. Here’s an example of the bug.
Keep in mind that the bug doesn’t execute when you click within the toolbar or the window, but obviously in a practical scenario clicking in order to disable this bug would be awful to have to do.
Not seeing this on my end, unless I’m performing these steps incorrectly. Here’s what I’ve done:
  1. Set tabs to vertical in Brave stable
  2. Moved them to display on the right (just to match yours)
  3. Set vertical tabs to Hide completely when minimized
  4. Display the browser in full screen
  5. Check to see if hovering over the area expands the tab strip (it does - expected behavior)
  6. Move mouse to and click on toolbar, then return and hover to see if tabs expand (they do)
You’re clicking within the toolbox every time you attempt, try hovering in the toolbar without clicking at all.
Ah yep, I see it. Thank you for clarifying.
I’ve let the team know about this and asked for the issue to be reopened and reviewed
Tysm! I did some extra testing on it and found that the thing that’s causing the bug is not the toolbox itself visually, instead there seems to be some sort of element behind or in front of the toolbar that creates it; I concluded this because it also executes the bug if I hover inside give or take a space of 20-40 pixels below the toolbar (along with anywhere inside the toolbar). This is especially annoying if you try to hover on the tab at the top, because this invisible element stretches into that space as well.
By the way, once the ticket has been accepted, I’d really appreciate if you sent me the Github link to the ticket, just so I can keep tabs on how things are going!
