Vertical Tab Bar Max Width Too Narrow
Brave on macOS now has a small maximum width for the vertical tab bar. I’d like to be able to adjust this maximum. At the very least, you guys could allow for seven pinned tabs per row so that we don’t have this awful, asymmetrical empty space to the right of the pinned tabs.
v1.80.115
Same here with Linux.
I hope the devs set max/min limits in a lenient way so it lets the user do what they want, especially with these types of settings where it’s very difficult to shoot oneself on the foot.
I switched to vertical tabs so I could see the actual tab titles; now I can only see less than half of the content most of the time…
Similar problem in Windows … Using vertical list for open tabs, suddenly the max width is way less than i typically leave it. Titles don’t fit!! Unsure why this was changed … I need to keep that list visible … Page titles matter
Thank you
I’m just going to use the Arc browser until this gets fixed.
It looks like this is already in Beta and will move to release in the near future. Here’s the comparison:
Today’s release sadly didn’t include that fix. Boo.
Yeah todays update was just a hotfix – mostly to include Chromium bump. The next scheduled browser update should include that fix.
v1.81.131 fixed it!
The maximum size is still too small. There should be an option to fill at least 75% of the page width.
Edge has a width that takes up half the page, which is much better than Brave.
TY so much to the devs for making this change …. However, i concur, the max width is still a bit limiting and i’m not sure why allowing users to set a very high-max would be, like, dangerous, or unacceptable. Today, though, my huge stack of previously unreadable page titles is visible again, so the step fwd is appreciated.
