Usability issue - no titlebar
Window does not have title bar. This leads to two usability issues:
  • Missing title of the page. There is just no place for it. At all.
  • Really hard to move window around. It takes an effort to land mouse in the thin band above tab bar.
  1. Open a window.
  2. Try to locate a space above tab bar.
  3. Try to point mouse in the few pixels above the tab bar and move window around.
  4. Try to find title of the page. Tabs are too narrow horizontally. What is meant to be titlebar is too narrow vertically.
Hard to move window around.
Hard to read title of the page.
A band of 5-10mm height above tabs. The band should have window manipulation controls (minimize/maximize/close) and title of the window. Dragging the titlebar should move window around. Doubleclick on the titlebar should maximize the window vertically.
Every time. 100%.
Mojave MacOS.
@cyr
Welcome, hope someone will answer you soon.
:leaves:
