I am trying to use the new gpt-5 model from OpenAI in the BYOM (bring your own model) mode of Leo AI, but it results in an error message “There was a network issue connecting to Leo, check your connection and try again.“
I have been able to successfully use Leo AI BYOM with gpt-4o and gpt-4.1 with the same API Key, and I’ve verified using curl that gpt-5 works fine with that same API Key. But not within Leo AI. Could it be that Brave automatically passes a temperature value to https://api.openai.com/v1/chat/completions because that does not work with gpt-5 (but works with all the older models)? If so, then that should be fixed or at least the temperature should be made into a parameter that can be adjusted in settings.
It seems like you understand the issue, but for others following along, this error occurs because GPT-5 accessed through the OpenAI API does not support the temperature parameter.
By the way, it would also be nice to be able to customize the reasoning_effort parameter when using a model that supports it.
If you don’t want to hold your breath waiting for Brave to update Leo to support GPT-5, I found this simple tool – kanna5/brave-byom-proxy – that routes requests to the OpenAI API through a local proxy, and strips the temperature parameter so you can use gpt-5 as the model.
To run it:
Install and run:
git clone https://github.com/kanna5/brave-byom-proxy.git
cd brave-byom-proxy
uv sync
uv run fastapi run main.py
