Every time i try to launch built-in models, such as mixtral or llama, i get the same error: “There was a problem connecting to Leo. Check your connection and try again.”. I added my own Mistral Large api - frankly, it worked just fine.
Issue occurs when i try using Leo AI
I want to be able use built-in models
1.71.118 Chromium: 130.0.6723.70 64bit
I use ubuntu 24.04. Back in the day when i used Windows this feature worked correctly. Also, i have got russian IP-address. May that be an issue?
