Since the last Brave update, elements of the Twitter interface have disappeared when you open the page with the Brave shields activated, either in “Standard” or “Aggressive”. Apparently it works normally when disabling the shields
URL: x.com
Does the site function as expected when Shields are turned off? Yes
Is there a specific Shields configuration that causes the site to break? If so, tell us that configuration. (yes/no): Yes
Brave 1.66.113, Chromium 125.0.6422.76
