harddy
1
Twitter mobile site is not working if Brave Shields are turned on. It says “Something went wrong, Try again!”
If I turn off the shields, only then I am able to view tweets and use the site.
- Go to https://mobile.twitter.com
- Login to your account.
- Make sure that the default Brave shields are on.
- It will not display tweets and instead show error.
Twitter mobile site should be accessible if shields are on.
1.5.131
Mobile Device details
Android 9
eljuno
2
Can you try disable “Block 3rd party cookies” option via Brave icon at URL bar?
harddy
3
Yes, disabling 3rd party cookies helped.
Thanks.
eljuno
4
Thanks for the confirmation @harddy. I’m able to reproduce the issue on my end and opened a new issue here
Thanks @eljuno for creating a separate issue. Ideally, Twitter should be accessible with 3rd party cookies blocked.
