It comes saying Tor not able to connect try by toggling Tor browser on and off or use bridges. On doing all possible ways, I was not able to connect it. Any suggestions on what to do?
See if anything helps from the above post
Try this and try connecting Tor after each step.
- Open
brave://settings/clearBrowserDataand clear Braveâs history. - Check if tor is not blocked by your firewall.
- Toggle ON/OFF âPrivate window with Torâ.
- Enable âUse Bridgesâ and try different ones.
- Flush DNS
- Use public DNS such as google 8.8.8.8, 8.8.4.4
- Open
brave://settings/securityand disable âAlways use secure connectionsâ and âUse secure DNSâ.
Actually, I recalled that in the distant past (over a year ago), the temporary fix was just to toggle the TOR setting (under âPrivacy and securityâ) â i.e., âoffâ, then back âonâ again (same as your #3).
So I did that and it worked. But I guess it means that thereâs been no permanent fix.
Thanks for your reply.
