when I open new Tor window, the Tor does not connect.
how can I establish tor connection?
windows 11 pro
**Brave Version v1.52.126
Hope your reply soon.
Best
windows 11 pro
Best
Try to use different bridges (settings - privacy&security - use tor bridges) or use vpn connection
Thanks for your reply.
But it does not work either.
and I dont use VPN.
it seems Brave does not try to connect to Tor. what happened with this problem?
Is there any solution on this?
