Top sites not working
hi guys
I just upgraded my laptop and for some reason when adding to my top sites , it sometimes just point blank doesnt add it , got me stump , as I say sometimes . And while im here , I cant remove that annoying polkofot add at the bottom lef
Thanks
Jason
Hi
For PC.
  1. For adding url to top sites visit I can't add favorite sites on my new tab - #3 by Crimsonmage21
  2. Polkodot if a sponsored image; to get rid of it, click on customise and disable “Show sponsored images”
Thanks will do it now.
Just one thi g though with the adding top sites It does work sometimes which I find a bit weird. But I’m going to follow your suggestions If you don’t hear from me you know it’s fixed it otherwise I’ll let ypu know
Thanks a million
I do apologize. I should is added that it is for windows 10 laptop
