The microphone does not work
Hi, I have been testing and the microphone does not work on any page.
I have already tried activating it from the browser, checking if privacy is enabled, disabling extensions and disabling the ad blocker, etc.
When I try to use the microphone to do a google search I get “No internet connection”.
And when I use it in gpt chat I get “voice recognition not supported in that browser”.
In other sites it doesn’t even work :frowning:
Brave version: 1.66.118
Does voice search or gpt chat voice recognition work in chrome properly?
The Google Search issue is known and being worked on:
For other sites, you’ll have to be more specific — which sites are you seeing the mic not work on? Did you allow the site permission to detect/use your microphone before trying to use it?
Can you try using your mic on this mic test website?
