NOTE: Any “one-liner” or topics requesting support or reporting bugs that do not make an effort to include as much of this information as possible will not be responded to. Repeatedly posting as such is grounds for banning._
- Not all settings sync between browser instances. Some do, some do not. I suspect it is by design.
- Turn on sync, and include settings.
- Every time
- Version 1.52.130 Chromium: 114.0.5735.198 (Official Build) (64-bit)
- Two Linux systems on NixOs
- One iPhone
Any time I setup a new system and add it to the sync chain, I have to go into settings and tweak many things I would like or would like to disable. Easy examples are the brave rewards, wallet-related stuff, the blank home page, etc.
I want a minimal experience with the browser.
Is there a way to make the browser settings an experience identical when I add a new device to my sync chain?
Thank you.
