Spotify web player not working on brave official build
It says " Enable secure playback in your browser" so I went to their support site and nothing works.
https://open.spotify.com/
Did the issue present with default Shields settings? Yes
Does the site function as expected when Shields are turned off? No
Is there a specific Shields configuration that causes the site to break? If so, tell us that configuration. (yes/no) : No it doesn’t work
Does the site work as expected when using Chrome? Haven’t tried it but it probably does
Brave version (check About Brave): [
Version 1.18.75 Chromium: 87.0.4280.101 (Official Build) (64-bit)]
Hello @Paradox2nd,
Happened for the first time? Did you have Widevine enabled? https://support.brave.com/hc/en-us/articles/360023851591-How-do-I-view-DRM-protected-content-
